方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
There have been quite a few types of equation of state and abundant pi-a curves of various lipid monolayers at the air-water or the oil-water interface in the literature. However, it has been a problem to interpret mechanochemical properties of bilayer vesicles from the pi-a information of the monolayer. In fact, even the bilayer surface pressure has not yet been well characterised although the monolayer surface pressure has already been traditionally defined as the lowering in the surface tension from the clean interfacial tension due to the presence of the monolayer. The monolayer-bilayer correspondence problem therefore could not be well defined and completely solved in spite of its importance in practice to apply the monolayer pi-a data to elucidate bilayer vesicle properties and to theoretically study biomembranes. In the present analysis, we thus firstly define the bilayer leaflet pressure as the intrinsic pressure of the lipid layer system, which is the sum of the net repulsive interaction of the lipids within the lipid layer and the hydrophilic interaction of the headgroups.
仪尊科技:温度对涤纶纤维力学性能的影响
仪尊科技:各向同性弹性体材料动态剪切模量
仪尊科技:向列式弹性体交联分布对动态力学性能的影响
