方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
An experimental study was carried out to study andcharacterize the capillary e.xtrudate swell and parisonswell behal-ior in extrusion blow molding of two commer-cial blow molding grade high density polyethylene resins.The capiIIa~ extrudate swell behavior of these resins weredetermined employing a capillary rheometer and a specialthermostatting chamber. Parison swell behavior was de-termined using an Impco Al3-R12 reciprocating screwblow molding machine in conjunction with cinematogra-phy and pinch-off. The experimental conditions underwhich capiiiaq extrudate and parison swell data can berelated are elucidated. Excellent agreement is found be-tween the area swell values determined on the basis ofcapillary and parison swell experiments.
仪尊科技:温度对涤纶纤维力学性能的影响
仪尊科技:各向同性弹性体材料动态剪切模量
仪尊科技:向列式弹性体交联分布对动态力学性能的影响
