方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract: To optimise heat transfer in industrial processing of plastics like injection moulding or extrusion it is necessary todetermine thermal conductivity under different pressures and temperatures.As an additional tool for capillary rheometer testing equipment a transient line-source sensor according ASTMD5930 for heat transfer measurement was developed. The test device is introduced. Measurement results of differentpolymer materials are presented. A strong influence on pressure and temperature can be observed. The results arecomparable to results obtained by other devices.
仪尊科技:温度对涤纶纤维力学性能的影响
仪尊科技:各向同性弹性体材料动态剪切模量
仪尊科技:向列式弹性体交联分布对动态力学性能的影响
