方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The hydrogen-absorbing intermetallic compound LaNi5 was activated using volumetric apparatus (a HTP1-V volumetric hydrogen storage analyser) at 333 K. Pressure-composition isotherms (PCIs) were measured through the first 8 hydrogenation cycles and show considerable change in the hydrogen absorption behaviour through the activation process. A series of isotherms at temperatures in the range 308 – 413 K were also measured. The higher temperature measurements show a clear indication of the formation of an intermediate phase between the solid solution phase and hydride phase. Van ‘t Hoff plots were determined from the measured isotherms and the average value for ΔH of 15.6 kJ/mol ½H2 was found to be in good agreement with the literature.
导热测试在石油石化行业中的应用
香烟成分的导热系数测试
北京英格海德:气利用IGA进行气体吸附表征和储氢研究
