方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The kinetics of uptake of gaseous HNO3 on thin films and crystallite grains of NaCl has been studied in a coated wall tubular flow reactor coupled to a quadrupole mass spectrometer. A rapid gas-solid reaction occurs with release of gaseous HCl. Uptake coefficients were measured at room temperature with a range of partial pressures of HNO3 and H2O in the flow tube. ç values decreased with increasing HNO3 concentration (4 1011 to 700 1011 molecule cm-3) and increased with H2O over the range 2 10-4 to 10 mbar. The results were interpreted in terms of a mechanism of the reaction HNO3(g) + NaCl(s) f HCl(g) + NaNO3(s), which involves ionization of adsorbed HNO3 molecules aided by surface-adsorbed water followed by reaction of H3O+ with Cl- and desorption of product HCl molecules. The results allow estimation of the reactive uptake coefficient for HNO3 on sea salt aerosol under atmospheric conditions.It consists of a Pyrex tubular reactor mounted vertically below a differentially pumped molecular-beamsampling quadrupole mass spectrometer (Hiden HAL RGA301) as illustrated in Figure 1.
导热测试在石油石化行业中的应用
香烟成分的导热系数测试
北京英格海德:气利用IGA进行气体吸附表征和储氢研究
