方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The isolation of a new fullerene dimer, C122H4, and its structural characterization by 13C NMR and 1H NMR spectroscopy and by UV/vis and IR spectroscopy are reported. The structure of this dimer consists of two fullerene cages, which are directly connected through two C-C bonds and two methylene bridges. Consequently, adjacent hexagonal faces of the two fullerene cages are arranged in a face to face manner. Molecular orbital calculations indicate that the proximity of the fullerene cages results in significant through space overlap in both the HOMO and LUMO. As a consequence of this overlap, the electrochemistry of the dimer shows electronic communication with stepwise reduction of each cage.
利用循环技术分离制备苯硅烷类化合物
对于硅胶敏感样品的分离
利用循环制备对硅胶色谱柱不能分离化合物的纯化
