方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The described High Temperature Heater Accessory for the Digital Instruments MultiMode AFM meets the strong demand for AFM measurements at elevated temperatures. The accessory accommodates several new features: probe heater, water-cooled scanner and environmental control for ensuring stable imaging of samples at temperatures up to 250ºC. The practical examples selected for this work demonstrate the capabilities of high temperature AFM studies with this accessory. Several other applications, which were accomplished using different prototypes of the heating stage, were reported earlier We believe that a broader use of this accessory for AFM applications to polymers will bring invaluable information for academic and industrial researchers.
台阶仪在三维形貌表征领域的应用
3D surface Profi ling applications
双焦面实时超高分辨系统Bruker3DVutura
多功能双光子成像平台Bruker2pplus
高品质双光子成像系统BrukerInvestigator
场扫描共聚焦成像系统BrukerOpterra II
布鲁克透射电镜专用原位纳米力学系统PI 95
布鲁克电镜专用原位纳米力学测试系统PI 88
布鲁克电镜专用原位纳米力学系统 PI 85L
布鲁克高精度纳米力学测试系统TI Premier
布鲁克高精度纳米力学测试系统TI 980
布鲁克三维光学显微镜Contour Elite
摩擦磨损试验机UMT-TriboLab
布鲁克原子力显微镜Dimension FastScan
探针式表面轮廓仪DektakXT
光学轮廓仪NPFLEX 3D
扫描探针显微镜系统Dimension Edge
