方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The AFM creates 3-dimensional images of a surface, covering, typically, an area up to 120µm square and height variations up to 7µm. It enables nanometer-scale in-plane, single-atomic step height, and sub-angstrom (rms) surface roughness measurements. The AFM is a non-destructive technique, ideal for measuring real devices on product wafers. The image analysis software of the AFM includes several methods for single as well as statistical measurements, which can often be automated and streamlined for repeated application. Automated AFMs are used in MEMS production, while highly modular AFMs are making measurements in R&D in MEMS labs. The AFM itself uses a simple MEMS device as its probe: a microfabricated beam and integrated tip. With highly specialized cantilever/tips, the AFM can nondestructively measure some of the most aggressive-geometry devices and smallest dimensions in MEMS and NEMS.
台阶仪在三维形貌表征领域的应用
3D surface Profi ling applications
双焦面实时超高分辨系统Bruker3DVutura
多功能双光子成像平台Bruker2pplus
高品质双光子成像系统BrukerInvestigator
场扫描共聚焦成像系统BrukerOpterra II
布鲁克透射电镜专用原位纳米力学系统PI 95
布鲁克电镜专用原位纳米力学测试系统PI 88
布鲁克电镜专用原位纳米力学系统 PI 85L
布鲁克高精度纳米力学测试系统TI Premier
布鲁克高精度纳米力学测试系统TI 980
布鲁克三维光学显微镜Contour Elite
摩擦磨损试验机UMT-TriboLab
布鲁克原子力显微镜Dimension FastScan
探针式表面轮廓仪DektakXT
光学轮廓仪NPFLEX 3D
扫描探针显微镜系统Dimension Edge
