方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 论文发表在“The Journal of Organic Chemistry” |
o-Dichlorobenzene was dried over anhydrous sodium sulfate and distilled prior to use.All reactions were performed in a commercial microwave reactor(XH-100A,100-1000W,Beijing Xianghu Science and Technology Development Co.Ltd,Beijing,P.R.China).The temperature of the reaction mixture was measured by an immersed platinum resistance thermometer.Melting points were measured on a melting point apparatus and are uncorrected.H NMR(200 or 300 MHz)and C NMR(50 or75MHz)spectra were obtained on an EI mass spectrometer.IR spectra were recorded on a FT-IR spectrometer with an OMNI sampler.TLC separations were performed on silica gel GF plates ,and the plates were visualized with UV light.
微波辅助分子内酯交换法合成环收缩红霉素A衍生物
超声与微波协同作用对转谷氨酰胺酶交联的乳清蛋白结构和功能特性的影响
微波辅助合成的新型类固醇希夫碱化学传感器用于检测水介质中的Al3+。
