方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 论文发表在“Food Chemistry” |
相比于索氏提取,时间更短,产率更高。 Abstract: The longan (Dimocarpus Longan Lour.) peel was extracted with 95% ethanol employing microwave-assisted extraction and Soxhlet extraction method, the total phenolic content of microwave-assisted extract of Langan peel (MEL) and Soxhlet extract of Langan peel (SEL) reached 96.78 mg/g and 90.35 mg/g dry weight, respectively, expressed as pyrocatechol equivalents, which were quanti?ed using Folin–Ciocalteu reagent. Subsequently, antioxidant properties of two extracts were investigated employing various established systems in vitro including 2,20-diphenyl-1-picrylhydrazyl (DPPH) radical scavenging assay, hydroxyl radical scavenging assay using a new resonance scattering (RS) method, reducing power and total antioxidant capacity. MEL and SEL showed excellent antioxidant in all test systems compared to synthetic antioxidant 2,6-di-ter-butyl-4-methylphenol (BHT) and the antioxidant activities of MEL were all superior to those of SEL. Furthermore, the suitability of MEL and SEL as substitute of BHT were determined in peanut oil, and the decrease of lipid oxidation were monitored using thiobarbituric acid-reactive substances (TBARS) assay. MEL and SEL treatment signi?cantly (P < 0.05) reduced lipid oxidation in peanut oil compared to the control. No signi?cant differences (P ? 0:05T in lipid oxidation were detected between MEL, SEL and BHT samples of peanut oil.
微波辅助分子内酯交换法合成环收缩红霉素A衍生物
超声与微波协同作用对转谷氨酰胺酶交联的乳清蛋白结构和功能特性的影响
微波辅助合成的新型类固醇希夫碱化学传感器用于检测水介质中的Al3+。
