资料下载The presence of a Nanonics NSOM/AFM-100 on any optical microscope stage, that is fitted on one port of the microscope with a laser scanning device for confocal or for non-linear microscopic imaging or for CCD computational deconvolution imaging, opens new unachievable worlds of investigation. As a first example of the unique perspectives a researcher can gain by having the Nanonics NSOM/AFM-100 working simultaneously with one of the above imaging modalities, consider the limitations in Z resolution of confocal or non-linear microscopes or for, that matter computational approaches with CCD cameras. Generously speaking the z resolution in such microscopes is 0.7 microns in fluorescence mode.
TLS-100
简介:The TLS-100 is a portable thermal conductivity meter used to measure thermal conductivity and thermal resistivity. Perfect for testing the thermal conductivity of soil, polymers, viscous liquids, and other soft materials; as well as testing the thermal conductivity of concrete, rock, stone, or other hard materials. Tests can be performed with the push of a button. The collected data is automatically analyzed and results are displayed immediately.
THW--L2
简介:The Transient Hot Wire (THW-L2) Liquid Thermal Conductivity Meter is an advanced measurement system for direct determination of the thermal conductivity of liquids and pastes in accordance with ASTM D7896. The THW-L2 was designed with speed and operational simplicity in mind. With a single measurement of less than 2 seconds in duration, small volumes of liquids and pastes can be accurately and precisely measured for thermal conductivity. The THW-L2 utilizes a non-stationary measurement approach and rapid test times to limit convective effects for samples with a wide range of viscosities.
HFM brochure
简介:The Heat Flow Meter (HFM) 100 is an easy-to-use rapid technique for the measurement of thermal resistance and thermal conductivity of insulation products, construction materials, packaging, and assemblies. Thermal conductivity is a measure of the ability of a material to conduct heat and can be critical for defining energy efficiency and thermal performance in materials. The Thermtest HFM has been designed and engineered to combine the highest accuracy, repeatability, widest temperature range, and industry leading performance, all at an exceptional value.
AAPS 2014 T3325 Spectrophotometric pKa determination
简介:AAPS 2014 T3325 Spectrophotometric pKa determination
Dissolution titration template method for solubility determination
简介:ScienceDirect-European Journal of Pharmaceutical Sciences:pH Metric Solubility
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
