方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Thermally sensitive poly(N-isopropylacrylamide) (PNIPAM) brushes grafted on SiO2-coated quartz crystal surface were prepared with a surface-immobilized initiator. Using quartz crystal microbalance (QCM), we investigated the collapse and swelling of the brushes in water in real time. Both frequency and dissipation of PNIPAM brushes were found to gradually change throughout a temperature range 20-38 °C, indicating that PNIPAM brushes undergo a continuous collapse transition in contrast with PNIPAM chains free in dilute solution exhibiting a sharp coil-to-globule transition. This result is in accordance with the previous theoretical prediction. The nonuniformity and stretching of PNIPAM brushes as well as the cooperativity between collapse and dehydration transitions are thought to be responsible for the continuity. On the other hand, a hysteresis was also observed in the cooling process. This is not only due to the intrachain and interchain interactions formed in the collapsed state but also to the nonuniform structure and stretching of the high-density brushes.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
