AFM+Raman
2007/01/09   下载量: 5
方案下载
应用领域
检测样本
检测项目
参考标准
We present a method for combined far-field Raman imaging, topography analysis and near-field spectroscopy. Surfaceenhanced Raman spectra of Rhodamine 6G (R6G) deposited on silver nanoparticles were recorded using a bent fibre aperture-type near-field scanning optical microscope (NSOM) operated in illumination mode. Special measures were taken to enable optical normal-force detection for control of the tip–sample distance. Comparisons between far-field Raman images of R6G-covered Ag particle aggregates with topographic images recorded using atomic force microscopy (AFM) indicate saturation effects due to resonance excitation.
方案下载
上一篇 PTT-显微拉曼-石墨烯检测
下一篇 A Blank Slate?
文献贡献者
相关方案
当前位置: 凯戈纳斯 方案 AFM+Raman
