方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Quick and easy to use the THT µMC™ allows multiple samples (up to 8) be studied simultaneously. The µMC is a heat flow calorimeter whereby the difference between sample chamber temperature and jacket temperature is used to determine the enthalpy of a reaction. The peltier control makes for rapid equilibration. Low volume (1.5ml or 4.0ml) disposable cells can handle solids, liquids and mixtures. Sample quantities can range from milligrams to grams. A variety of operation modes are possible, namely Isothermal, Step-Isothermal or Scanning.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
