方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Solubility is an important parameter with relevance to drug absorption. Poor solubility can result in erratic oral absorption and poor bioavailability. Of further interest, is the susceptibility of compounds to transform from one solid form to another with different physical properties. In this study, two different polymorphs of a proprietary Boehringer Ingelheim compound, BIX 011397 (polymorph III) and BIX 011398 (polymorph I) were investigated by the CheqSol (Chasing Equilibrium Solubility, patent applied for) method for equilibrium solubility measurement.1, 2 The method dissolves and partially reprecipitates ionizable compounds using a GLpKa/D-PAS titration system that can repeatably cycle the solution between a supersaturated and subsaturated state. Accurate solubility values are determined from the transition between the supersaturated solution (with solid precipitating) and the subsaturated system (with solid redissolving). The objective was to investigate the feasibility of detecting polymorphic conversions whilst performing these equilibrium solubility studies. Comparisons were made to traditional shake-flask measurements, and solids were characterized using TGA, DSC, microscopy and XRPD methods.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
