方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The adsorption kinetics of three model proteins—human serum albumin, fibrinogen and hemoglobin—has been measured and compared using three different experimental techniques: optical waveguide lightmode spectroscopy (OWLS), ellipsometry (ELM) and quartz crystal microbalance (QCM-D). The studies were complemented by also monitoring the corresponding antibody interactions with the pre-adsorbed protein layer. All measurements were performed with identically prepared titanium oxide coated substrates. All three techniques are suitable to follow in-situ kinetics of protein–surface and protein–antibody interactions, and provide quantitative values of the adsorbed adlayer mass. The results have, however, different physical contents. The optical techniques OWLS and ELM provide in most cases consistent and comparable results, which can be straightforwardly converted to adsorbed protein molar (‘dry’) mass. QCM-D, on the other hand, produces measured values that are generally higher in terms of mass. This, in turn, provides valuable, complementary information in two respects: (i) the mass calculated from the resonance frequency shift includes both protein mass and water that binds or hydrodynamically couples to the protein adlayer; and (ii) analysis of the energy dissipation in the adlayer and its magnitude in relation to the frequency shift (c.f. adsorbed mass) provides insight about the mechanical/structural properties such as viscoelasticity. © 2002 Elsevier Science B.V. All rights reserved.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
