方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
We have studied the adsorption kinetics of a small monomeric protein S6 using the quartz crystal microbalance with dissipation monitoring (QCM-D) technique. Competitive adsorption from various proportions of native (Nat) and denatured (Den) protein in the bulk phase was carried out using a range of chemical denaturant concentrations. The ratio between Nat and Den in bulk has a profound affect on the adsorption behavior, most obvious from a significant (one order of magnitude) increase in the rate of a lag/ and consolidation/adsorption phase when Nat is the major species present in bulk, signaling that these adsorption phases originates from the Den fraction of proteins in the bulk. To determine whether the kinetics of protein unfolding in the bulk phase are rate-limiting for adsorption of Nat, the adsorption kinetics of wildtype S6 with the mutant VA85 (whose unfolding kinetics are around 30 times more rapid under conditions of equal thermodynamic stability) were compared. It is concluded that adsorption of Nat is not ratelimited by the rate of unfolding in solution, leading to the speculation that Nat, upon binding on the surface, is trapped as a misfolded state whose structural dynamics do not correlate with those of Nat.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
