方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
In this paper, the Raman intensity enhancement induced by nanoprobes (metal particles and metallized tips) in the vicinity of a strained silicon sample surface is reported. For silver nanoparticles deposited directly onto silicon, high enhancements in the vicinity of particles were observed. Furthermore, metallized tips were scanned inside the spot of a laser used for the Raman measurements. Both silver coated and pure silver tips, mounted to a tuning fork, indicated high Raman signal enhancement for optimized tip position within the laser spot. Atomic Force Microscopy (AFM) scanning on a structured sample was conducted to investigate the stability of these tips. Focused Ion Beam (FIB) milling was utilized to refine and to re-sharpen pure silver tips after the measurements. Complementary measurements were performed using pure tungsten tips. Because of the high hardness of W wires, a special pre-etch technique was applied.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
