方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Introduction In this application note an extruded PS sample certified by NIST has been tested with the Hot Disk Thermal Constants Analyser in order to compare the results with the results obtained with the methods used at other laboratories. By marking each side of each sample with “1” for low side and “2” for upper side, it was possible to test four permutations of the sample set-up and thus it could be possible to analyse possible differences between the upper side and the lower side of the samples as they were manufactured. Since the sample is formed by extrusion,it is assumed that the PS will have a higher density on the bottom side of the sample than the upper side and therefore different thermal properties.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
