方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Effective thermal conductivity (ETC) of both tetrahydrofuran (THF) and methane hydrate-bearing sandy porous media was measured by the Hot Disk Thermal Constant Analyser. Thermal conductivity of methane hydrate is 0.575 W m−1 K−1 at 0°C and 6.6 MPa (methane gas pressure), which is close to THF hydrate''s 0.51 W m−1 K−1 at 0°C and 0.1 MPa (atmosphere pressure). However, the measured 1 W m−1 K−1 ETC of methane hydrate-bearing sand is significantly lower than that of THF hydrate-bearing sand at ∼2 W m−1 K−1. This is because the methane hydrate formed with a sodium dodecyl sulfate (SDS) solution in sand at our laboratory has a “wall creeping” growth characteristic and consequently a large part of the pores were filled with methane free gas. ETCs of sand containing gas hydrates were also calculated using a renormalization method. The process involves sample partitioning, labeling, initial value assignments, and renormalization calculations. A Monte Carlo analysis was applied to sample laboratory-scale gas hydrate-bearing sand assemblies. We found that the renormalization modeling results agreed well with measured ETCs when each photo of a 1.3 mm × 1.3 mm subsample was divided into 16 or more blocks.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
