方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A new, novel Micro Reaction Calorimeter is described. Reaction calorimetry has applications in many areas of chemistry. A reaction calorimeter will measure heat output of chemical reaction you do or do not want (process optimisation and safety); kinetics of reaction and thermodynamics of reactions can be quantified. But, in addition, a reaction calorimeter will determine specific heat, heat of solution, heat of mixing. Solids, liquids or mixtures can be measured. Applications range from kinetic studies for process development to evaluation of catalysts or other additives; from stability of explosives to specific heat determination of heterogeneous mixtures. Pressure also can be measured. Until now, reaction calorimeters have been large glass vesselled instruments, have been of low sensitivity, slow in set-up and operation (1 test per day) and with a requirement often of 1 – 2 litres can cause hazard in operation or difficulty if sample availability is limited. Often commercially, they are very expensive. A Micro Reaction Calorimeter overcomes all these issues. Application of the Micro Reaction Calorimeter is detailed in this paper. Key words: reaction calorimeter; safety; process development; heat of reaction; kinetics; thermodynamics
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
