方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A collection of AlSi7 closed cell foams of densities between 500 kg/m3 and 1300 kg/m3 were produced following the powder metallurgical route [1,2]. On the one hand, thermal conductivity of the samples has been measured by means of the transient plane source (TPS) technique [3,4]. Values obtained showed the increase of thermal conductivity values with density. On the other hand, the TPS technique has been tested as a tool to detect in-homogeneities derived from the manufacturing process. The results obtained have proved the ability of this method to detect these in-homogeneities, and its possible use as a non – destructive quality control method.
PTT-显微拉曼-石墨烯检测
凯戈纳斯:Hot Disk瞬态平面热源法在建筑节能材料测试中的应用
凯戈纳斯:近场光学显微镜与传统光学显微镜的对比介绍
SYMCEL 生物代谢活性微量热仪 CalScreener
Advance Riko高温润湿性及接触角测量仪 WET-1200
SAL-3000Plus ALD原子层沉积系统
SAL3000原子层沉积系统
GMDX-便携拉曼
Mila-5050 2英寸快速退火炉
日本Antares微生物代谢微反应热测试系统
SSP-1000桌面型磁控溅射系统
AGUS-SPS-2000放电等离子烧结系统
SAL1000 系列桌面型ALD原子层沉积系统
SERSTECH一键式手持型拉曼光谱仪100
电弧等离子体沉积系统
AGUS-SPS放电等离子烧系统(Rx系列)
AGUS-SPS放电等离子烧系统(Sx系列)
Advance Riko高温显微镜TMS-E1S
