方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
薄层层析-紫外分光光度法测定香丹注射液中原儿茶醛的含量 薄层层析-紫外分光光度法测定香丹注射液中原儿茶醛的含量 作者:偶志红,徐丹丹,郭薇 【摘要】 目的 建立薄层层析-紫外分光光度法测定香丹注射液中原儿茶醛的含量。方法 以原儿茶醛为对照品,展开剂为二氯甲烷-乙酸乙酯-甲酸(8∶5∶0.8)分离得到原儿茶醛,采用紫外分光光度法,检测波长281nm,测定原儿茶醛的含量。结果 原儿茶醛在0.55~4.95μg/ml 范围内线性关系良好,r=0.9998。平均含量为0.174mg/ml,加样回收率为97.3%~102.3%,RSD为1.6%。结论 实验结果表明,薄层层析-紫外分光光度法测定香丹注射液中原儿茶醛的含量,方法操作简便,准确度高,精密度好,可作为样品的检测方法。 【关键词】 香丹注射液;原儿茶醛;薄层层析-紫外分光光度法;含量测定 【Abstract】 Objective A TLC-UV method was developed to separate and determine protocatechuic aldehyde in injection saliae miltiorrhizae composita.Methods Contrasting with protocatechuic aldehyde, the amount of protocatechuic aldehyde in injection saliae miltiorrhizae composita have been determined by TLC-UV with methylene chloride-acetic acid acetic ester-formic acid(8∶5∶0.8)as the developing solvent and the detection wavelength at 281nm.Results The calibration carver was linear in the range of 0.55~4.95μg /ml (r=0.9998)for protocatechuic aldehyde .The average amount is 0.174mg /ml.The recoveries of protocatechuic aldehyde are between 97.3% and 102.3%,and RSD% was not more than 2.0%.Conclusion The method is simple,rapid and reproducible for determination of protocatechuic aldehyde in injection saliae miltiorrhizae composita. 【Key words】 injection of saliae miltiorrhizae composita;protocatechuic aldehyde;TLC-UV;content determination 香丹注射液为棕色澄明液体,是由降香和丹参提取物配制而成,临床用于治疗心绞痛、
优选 固相微萃取(SPME)
型号:SPME优选 DVB/CAR/PDMS 50/30UM SPME纤维头二乙烯基苯羧基聚二甲基硅氧烷固相微萃取头探针
型号:57328-U/57329-U挥发性和半挥发性C3-C20大范围通用万能SPME萃取头优选 SPME固相微萃取萃取头二甲基硅氧烷/二乙烯基苯(PDMS/DVB 65UM)固相微萃取纤维头
型号:手动57310-U/自动57311MERCK默克Supelco色谱科sigma西格玛优选 固相微萃取纤维头组合套件2萃取头套装二MERCK默克sigma西格玛Supelco色谱科
型号:57320-U/57321水中的挥发性或极性有机物水质9种烷基酚类化合物和双酚A测定HJ1192-2021SPE固相萃取装置水质分析安全中的应用
固相微萃取氮吹仪固相萃取装置食品行业使用品牌型号厂家规格技术参数选择
氮吹仪和固相萃取装置SPE小柱等国标GB 5009.111-2016食品中脱氧雪腐镰刀菌烯醇及其乙酰化衍生物的测定
