资料下载Cyclic voltammetry was used to investigate the electrochemical behaviour of the tungsten oxide films toward the electroreduction of BrO3−,ClO2− and NO2− ions in acidic medium. The effects of the temperature, scan rate, pH, chemical composition of the electrolytic solutions,were investigated and the reduction mechanism was critically discussed.The reduction currents, evaluated in cyclic voltammetry and measured at −0.250V versus SCE, increased linearly on increasing analyte concentration up to 20, 55 and 45mMfor nitrite, chlorite and bromate ions, respectively. The detection limits, evaluated in cyclic voltammetry,were 0.1, 0.4 and 0.7mM for BrO3−, ClO2− and NO2−, respectively.The tungsten oxide film was successfully characterized as an amperometric sensor for the analytical determination of BrO3−, ClO2− and NO2− ions in flowing stream. Operating under constant applied potential of −0.3V versus Ag/AgCl the good reproducibility of the peak height and background current level during consecutive injections, indicates the absence of fouling effects and the potential applicability of the amperometric sensor for the routine analytical determination of the investigated inorganic ions. Considering the low values of the background currents (ca. 1.1±0.1A) obtained in acidic and not deoxygenated carrier electrolyte, the tungsten sensing electrode seems to compete favourably with other common sensors for the amperometric determination of electroactive molecules under cathodic conditions.The X-ray photoelectron spectroscopy technique (XPS) was used in order to evaluate the chemical composition of the tungsten film upon electrochemical treatment in 0.1M H2SO4 solution. Independently of the electrochemical treatment in acid solution, the tungsten surface electrode is generally composed by 50–60% of W0, 35–40% of W6+ and traces of W2+ oxide species.
LK2006仪器软件演示版
简介:LK2006仪器软件演示版,可以下载直接使用。如想了解更多信息请拨打营销中心电话 022-23858107,23858108.联系人:孙建东
LK2005演示版
简介:LK2005仪器软件演示版,可以下载直接使用。如想了解更多信息请拨打营销中心电话 022-23858107,23858108.联系人:孙建东
人体微量元素与食物
简介:钙是构成人体的常量元素,它是骨骼和牙齿的主要成分。构成人体骨骼和牙齿的骨盐组成是:Ca3(PO4)2 85%,CaCO3 10%,Mg3(PO4)2 1.5%,CaF2 0.3%,CaC12 2.0%。人体中99%的钙存在于骨骼和牙齿中。钙有助于骨骼和牙齿的生长,促进肌肉和神经的正常兴奋。
