Electrochemical and spectroscopic characterization of a tungsten
2006/03/03   下载量: 264
方案下载
应用领域
检测样本
检测项目
参考标准
Cyclic voltammetry was used to investigate the electrochemical behaviour of the tungsten oxide films toward the electroreduction of BrO3−,ClO2− and NO2− ions in acidic medium. The effects of the temperature, scan rate, pH, chemical composition of the electrolytic solutions,were investigated and the reduction mechanism was critically discussed.The reduction currents, evaluated in cyclic voltammetry and measured at −0.250V versus SCE, increased linearly on increasing analyte concentration up to 20, 55 and 45mMfor nitrite, chlorite and bromate ions, respectively. The detection limits, evaluated in cyclic voltammetry,were 0.1, 0.4 and 0.7mM for BrO3−, ClO2− and NO2−, respectively.The tungsten oxide film was successfully characterized as an amperometric sensor for the analytical determination of BrO3−, ClO2− and NO2− ions in flowing stream. Operating under constant applied potential of −0.3V versus Ag/AgCl the good reproducibility of the peak height and background current level during consecutive injections, indicates the absence of fouling effects and the potential applicability of the amperometric sensor for the routine analytical determination of the investigated inorganic ions. Considering the low values of the background currents (ca. 1.1±0.1A) obtained in acidic and not deoxygenated carrier electrolyte, the tungsten sensing electrode seems to compete favourably with other common sensors for the amperometric determination of electroactive molecules under cathodic conditions.The X-ray photoelectron spectroscopy technique (XPS) was used in order to evaluate the chemical composition of the tungsten film upon electrochemical treatment in 0.1M H2SO4 solution. Independently of the electrochemical treatment in acid solution, the tungsten surface electrode is generally composed by 50–60% of W0, 35–40% of W6+ and traces of W2+ oxide species.
方案下载
配置单
上一篇 天津兰力科:罐头中铅检测(电化学工作站)
下一篇 Renewable Surface Sol-gel Derived Carbon Ceramic Electrode
文献贡献者
相关方案
当前位置: 天津兰力科 方案 Electrochemical and spectroscopic characterization of a tungsten
