资料下载Overview The VersaSTAT MC, an all-new multichannel potentiostat / galvanostat / impedance analyzer , is an impressive combination of value, performance, and productivity providing everything you would expect from a high-quality electrochemical test system.營ts development combines over forty years of Princeton Applied Research knowledge and expertise in the research and development of world leading electrochemical test products. Characterized by advanced performance from the very latest measurement technology,爄ts easy-to-use, yet powerful PC software makes the VersaSTAT MC a versatile, research-grade, high-performance workhorse capable of addressing a multitude of applications. Corrosion research; battery, fuel cell and supercapacitor research; research electrochemistry; biomedical applications; and educational/teaching applications are among its broad capabilities. Versatile performance in choice of 1-4 channels at an affordable price ?the ideal choice for performance, productivity, and value ?50mA / ?0V polarization range as standard ?ideal for most electrochemical applications including corrosion, sensors, and biomedical Impedance measurement capability standard on all channels simultaneously and/or independently from 10uHz to 1MHz with no separate analyzer required Options for each channel include ?2A high current option and boosters up to 20A for battery, fuel cell, or electroplating applications High speed DC measurement and experiment sequencing (e.g. for step / pulse analysis) V3Studio software designed for versatility and ease of use The VersaSTAT MC was designed to have the broad capabilities of a research-grade, single-channel, electrochemical system along with the value and increased throughput provided by multichannel systems.
输力强光电测试系统DSSC
简介:输力强光电测试系统DSSC样本,包含Modulab模块及光学平台,测试方法包含:IMPS,IMVS,EIS,I-V,电荷抽取等。
ModuLab MTS 材料电特性测试系统
简介:ModuLab MTS(材料电特性测试系统)是模块化的,完全整合的研究系统,可用来测试从绝缘体到超导体的大部分材料的电学性质。此测试系统即提供时域技术,如恒定电流,通过脉冲电压和扫描电压(I-V)确定材料的电学性能;又提供AC技术如阻抗、电容、C-V或者Mott-Schottky来提供更多细节信息进一步分析材料的导电机理;并且仪器提供一系列可选模块,扩展了测试范围,如高电压、样品/参比、功率放大器和低电流测试;高/低温系统及样品架配件更提高了其测试能力。系统有两种尺寸配置,满足不同预算,可以配合您的研究,为您量身定做,适应和拓展您的研究深度和广度。
能源应用测试软件介绍
简介:全新的能源研究专业应用软件,成功的整合于VersaStudio 软件平台之中,提供一整套定制的实验方法和模板,致力于能源研究和开发领域的应用,尤其是电池,燃料电池和电容器等。
VersaSTAT系列多功能电化学工作站
简介:VersaSTAT 是一款由普林斯顿应用研究集50 多年在电化学测试仪器专业制造的技术和经验上研发的电化学综合测试仪。VersaSTAT 支持进行全面的电化学技术测试;配备功能强大、使用方便的VersaStudio 软件,使VersaSTAT 成为现今市场上极具性价比的电化学工作站。 高性能的VersaSTAT 电化学综合测试仪 将为您的科研带来极大的方便 ~±650mA(V3 、V3F),±1A(V4 )电流范围 ~±10V 的电压极化范围,支持多数电化学应用、腐蚀、传感器、生物电化学; ~2A 电流输出可选,最大到20A 电流放大器,支持化学电源、燃料电池、电镀等应用对大电流的要求; ~良好的电流测试精度,可用于腐蚀、涂层评价以及微电极分析; ~内建FRA 频响分析仪(可选),支持电化学阻抗测试,频率范围10μHz-1M Hz; ~浮地选项(VersaSTAT 3F); ~标配Versa Studio 软件支持全系列单通道及多通道电化学综合测试仪,包括小电流附件、大电流扩展和电流放大设备; ~各种系统综合性的软硬件完美结合,新增能源应用软件,使Studio 可以致力于各个领域中的研究,并且通过不同的预算不断升级;
VersaScan微区扫描电化学工作站 样本
简介:VersaScan微区扫描电化学工作站是一个建立在电化学扫描探针的设计基础上的,进行超高测量分辨率及空间分辨率的非接触式微区形貌及电化学微区测试系统。 它是提供给电化学及材料测试以极高空间分辨率的一个测试平台。每个VersaSCAN都具有高分辨率,长工作距离的闭环定位系统并安装于抗震光学平台上。不同的辅助选件都安装于定位系统上,辅助选件包括,如电位计,压电振动单元,或者激光传感器,为不同扫描探针试验,定位系统提供不同的功能。VersaSTAT恒电位仪和Signal Recovery 7230锁相放大器和定位系统整合在一起,由以太网来控制,保证小信号的精确测量。 它 是一个模块化配置的系统,可以实现如下现今所有微区扫描探针电化学技术以及激光非接触式微区形貌测试: Scanning Electrochemical Microscopy (SECM) 扫描电化学显微镜 Scanning Vibrating Electrode Technique (SVET) 扫描振动电极测试 Scanning Kelvin Probe (SKP) 扫描开尔文探针测试 Localized Electrochemical Impedance Spectroscopy (LEIS) 微区电化学阻抗测试 Scanning Droplet Cell (SDC) 扫描电解液微滴测试 Non-Contact Surface Profiling (OSP) 非触式光学微区形貌测试 以上每项技术使用不同的测量探针,且安装位置与样品非常接近,但是不接触到样品。随着探针测试的进行,改变探针的空间位置。然后将所记录的数据对探针位置作图,针对不同技术,该图可以呈现微区电化学电流,阻抗,相对功函或者是表面形貌图。
