方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The Mo-doped LiNi0.5 Mn1.5O4 cathodes are successfully synthesized by citric acid-assisted sol–gel method. The result demonstrates that the Mo-doped LiMn1.4Ni0.55 Mo0.05O4 cathodes present the improved electrochemical performance over pristine LiNi 0.5 Mn1.5O4. At the 2 C rate after 80 cycles, the discharge capacities are 68.5 mAh g-1 for the pristine LiNi0.5 Mn1.5O4material (53.9% of the capacity at 0.1 C), 107.4 mAh g-1 for the LiMn1.425Ni0.5 Mo0.05O4material (82.1% at 0.1 C), and 122.7 mAh g-1 for the LiMn1.4Ni0.55 Mo0.05O4 material (90.5% at 0.1 C).
普林斯顿及输力强:恒电量瞬态扰动测量Tafel 斜率及数据积分处理
普林斯顿及输力强:薄层缓释剂液膜对907A钢防腐蚀效果的电化学测量技术
普林斯顿及输力强:缓释剂对船用钢在潮湿大气中的防蚀研究
