方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Sulfonated chitosan (S-CTS) doped polyaniline (PANI) was synthesized by “template-free” method successfully, and it is reported as corrosion inhibitor for the first time. The corrosion inhibition property of PANI was demonstrated for mild steel in acidic environment using weight loss test, Tafel polarization, electrochemical impedance spectroscopy (EIS), scanning electronic microscope (SEM) and adsorption isotherm.
普林斯顿及输力强:恒电量瞬态扰动测量Tafel 斜率及数据积分处理
普林斯顿及输力强:薄层缓释剂液膜对907A钢防腐蚀效果的电化学测量技术
普林斯顿及输力强:缓释剂对船用钢在潮湿大气中的防蚀研究
