资料下载Dear User! We present you a device distinguished by accuracy according to the technical data and by a high stability of the displayed results. We believe that the measurements will not cause you any trouble and that the meter will operate without any inconvenience. Wide range of additional functions requires careful reading of the manual in other case some of the features may stay unused or using the meter may cause you a troubles. The employing of good-quality electrodes cells and probes and their replacing after a suitable time ensures obtaining of high measuring parameters. We want to call your attention to the fact, that this equipment has a much shorter working life than the meter. Typical symptoms of an improper operation of the electrode are deterioration of final result stability, it’s flowing as well as a higher measuring error. Part of the users has problems, arising from employing electrodes not being preconditioned before the measurement or making the measurements without removing the shielding ring from the liquid junction or taking measurements with a plugged junction. To avoid this situation it is necessary to choose the proper kind of electrode for solutions which are going to be measured ex. special electrodes for the sewage, liquids with deposits, meat cheese etc. Therefore, if you observe improper operation of the device, please take control measurements with another electrode or check the used electrode with another pH-meter. Generally the deterioration of the meter work is caused by the electrode and not by the meter. In case of conductivity measurements it is important to choose the cell with right constant K value for the measuring range. Wrong selection may cause larger error occur, similar situation occurs during measurements with automatic temperature compensation with incorrectly introduced  coefficient. Accuracy of the dissolved oxygen measurements depends on the sensor calibration and regular maintenance which consist in replacing the membranes, electrolyte and cleaning the electrodes. Lack of correct maintaining of the sensor after some time will make measurements impossible. Please turn your attention to the fact that stabile measurement is possible only with simulated or natural measured water flow. The essential feature of our products is their low failure frequency. However if your meter will fail, our firm immediately performs its warranty repair. We wish you a pleasant and trouble-free work with our meter.
水和废水监测分析方法
简介: CleverChem 200全自动多参数水质分析仪采用国际先进技术,测量全过程由电脑控制,自动化程度高,操作过程简易,分析结果精确可靠,符合ISO、EPA、AOAC、BATF、AFNOR、COFRAC等国际认证标准,广泛用于饮用水、地表水、废水、海水分析,是最新一代全自动水质分析仪。
城市供水水质标准
简介:本标准规定了供水水质要求、水源水质要求、水质检验和监测、水质安全规定。 本标准适用于城市公共集中式供水、自建设施供水和二次供水。 城市公共集中式供水企业、自建设施供水和二次供水单位,在其供水和管理范围内的供水水质应达到本标准规定的水质要求。用户受水点的水质也应符合本标准规定的水质要求。
GB/T 5750.11-2006 生活饮用水标准检验方法 消毒剂指标
简介:水中二氧化氯浓度检测的国家标准,美国HF公司生产的余氯总氯测定仪及二氧化氯测定仪均是建立在该标准基础之上
BALOMETER风量罩
简介:美国TSI全新模拟型风量罩ALNOR提供可用于通风和平衡度检测的有用工具.ABT700型风量罩可快速并简便测试并显示散流器和隔栅的风量,可有效提供测试效率.
RE-501旋转蒸发仪
简介:RE-501是目前具备最先进安全性的旋转蒸发仪的代表性产品。设计之初,它就被赋予了最优异的性能和最安全的防护。仪器运行过程中,无论是加热还是移动时,透明防护罩都为用户和工作环境提供了最大限度的保护。免维护的机械密封系统能保持恒定的真空度。微电脑控制系统带LCD触摸屏,可多重编程,用户可以根据需要随时调整和修改所有参数。RE-501通过了GLP认证 (良好实验室规范)。仪器可连接真空控制器和温度探头,蒸馏瓶驱动部分可由电机控制自动升降。 旋转蒸发仪RE-501采用人体工程学设计,具有良好的操控性和卓越的性能。RE-501设计之初就已经考虑到安全防护方面的需要,并在产品制造和电磁兼容性方面符合所有现行标准。
