资料下载We have investigated the alignment of poly (9,9-dioctylfluorenyl-2,7-diyl) (PFO) induced by a photo-aligned polyimide film, which is optically, thermally, and chemically stable. The ∼30 nm-thick PFO layer was spin-coated onto a photo-aligned polyimide film. Slow cooling and quenching of the sample from the liquid crystalline phase of PFO formed uniaxially-aligned crystalline and glassy layers of PFO, respectively. For comparison, we also investigated the alignment of PFO induced by a rubbed polyimide film. For the crystalline PFO layer on the photo-aligned film, an extremely high polarization ratio was observed in photoluminescence (PL), which was ∼30. It was much larger than that of the crystalline PFO layer formed on the rubbed film (∼20). Indeed, such a high PL polarization ratio has not previously been reported in crystalline PFO layers formed by any other alignment method. For the glassy PFO layer formed on the photo-aligned film, the PL polarization ratio was 10.8. It was slightly larger than that of the glassy PFO layer on the rubbed film (9.5). These results show that the photo-aligned polyimide film used in this study is an excellent alignment film for PFO layers, especially for crystalline layers.
GemRam 珠宝标准库
简介:292种各地产珠宝.主要涉及翡翠了、玉石、宝石金刚石等。 瑞士著名机构提供标准库,专用软件可以进行拉曼光谱库扩充、识别等功能。
拉曼专用激光器
简介:必达泰克公司专用于拉曼光谱仪的Cleanlaze系列激光器,具有高稳定性,窄线宽等优点,适合于拉曼光谱应用
BTC261E近红外光谱仪重复性测试报告
简介:本文以95%乙醇为样品测试BTC261E的吸光度重复性,测得其吸光度重复性均方根误差为1.1772E-4.
双通道近红外光谱仪系统BWS225的配置与应用
简介:本文对本公司的双通道近红外光谱仪系统BWS225的技术特点及其应用作了比较详细的介绍,采用该双通道近红外光谱仪系统,克服了单通道近红外光谱仪系统由于更换参比与样品以及光源本身所带来的不稳定性,同时也在一定程度上降低了系统的成本。该系统同样可用于UV-VIS波长段的应用。
天然珊瑚与染色珊瑚的拉曼测试报告
简介:使用i-Raman小型拉曼光谱仪结合BAC151显微拉曼检测平台,对3种天然珊瑚与3种染色珊瑚进行检测。激发波长785nm,300mW出口功率,放大倍数20X,焦长8.7mm.检测结果显示天然珊瑚与染色珊瑚的拉曼光谱有所区别。
