方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The Interfacial Rheology System combines the outstanding and well-established properties of a Physica MCR rheometer with a newly developed interfacial rheology cell based on a bi-cone geometry. This bi-conical disk rheometer allows the measurements of steady state and transient interfacial shear viscosities as well as elasticity properties of interfacial films and layers. The use of a research rheometer extends the range of standard rheological test methods like flow curve, creep and creep recovery, stress relaxation or oscillatory measurements which are common in three-dimensional bulk rheology to the rheology of two-dimensional interfaces. The sensitivity of the Physica MCR rheometer at low torques gives the opportunity to investigate interfacial films with very low viscosities. It even extends the application range of the biconical geometry, which was thought to be exclusively for measurements at liquid/liquid interfaces, to rheological experiments on layers at the air/water interface. The influence of the bulk phase contribution is taken care of by a full hydro-dynamical analysis of the flow field for a bi-cone geometry allowing a quantitative determination of the relevant interfacial rheological properties.
MultiWave PRO 微波消解铂依合金
煤炭中硒含量的测定
重水含量或纯度的鉴定
安东帕康塔全自动比表面和孔径分布分析仪Autosorb-iQ
安东帕康塔比表面和孔径分析仪:Nova系列
安东帕Anton Paar粘度计SVM 1001
安东帕Anton Paar啤酒分析系统Alcolyzer Beer Analyzing System
安东帕Anton Paar全自动成品啤酒分析系统PBA 5001 Beer
纳米压痕测试仪:Hit 300
安东帕自动化多用途粉末X射线衍射仪
SAXS/WAXS/GISAXS/RheoSAXS 实验室光束线装置
紧凑型拉曼光谱仪Cora 5001
安东帕多参数分析系统:Modulyzer
安东帕Anton Paar在线二氧化碳传感器Carbo
安东帕Anton Paar低温冰粘密浊多功能测定仪SVM 3001
安东帕Anton Paar饮料色度传感器L-Col
安东帕L-Dens 2300 密度传感器
安东帕Anton Paar在线声速传感器L-Sonic
