方案下载应用领域 | 石油/化工 |
检测样本 | 橡胶制品 |
检测项目 | |
参考标准 | 无 |
采用安东帕微波消解仪配备微波氧燃烧技术样品处理,采用ICP-OES检测,对含炭黑橡胶中国的Al, Fe, Mn, Sr 和Zn痕量元素进行检测。
A rapid digestion procedure for the determination of Al, Fe, Mn, Sr and Zn in carbon black-containing elastomers (30%) has been developed using sample combustion in closed quartz vessels. Microwave radiation was used for ignition. Combustion takes place in the presence of oxygen under pressure using ammonium nitrate (50 μl of 6 mol l−1) as aid for ignition. Samples of nitrile-butadiene rubber and ethylenepropylene-diene monomer were decomposed. A quartz device was used simultaneously as a sample holder and for the protection of vessel cap. The influence of the absorption solution (nitric acid or water) and the necessity of an additional reflux step were evaluated. Determination of Al, Fe, Mn, Sr and Zn was performed by inductively coupled plasma optical emission spectrometry. A reference method (ASTM D 4004-06) based on conventional dry ashing and flame atomic absorption spectrometry was used for comparison (Mn and Zn). Results were also compared to those obtained by using wet acid digestion in closed systems. Concentrated and diluted (4 mol l−1) nitric acid, with 5 min of reflux after the combustion, gave best recoveries for all analytes (from 97 to 101%). For dry ashing quantitative recoveries were found only for Zn whereas for Al, Fe, Mn and Sr the recoveries were only 14, 37, 72 and 37%, respectively. With the proposed procedure the residual carbon content was below 0.5% and further determination of analytes was feasible with only the combustion step (for Fe a reflux with diluted HNO3 was necessary). Complete sample digestion is obtained in less time using the proposed procedure than with other procedures and no concentrated acids were necessary.
MultiWave PRO 微波消解铂依合金
煤炭中硒含量的测定
重水含量或纯度的鉴定
安东帕康塔全自动比表面和孔径分布分析仪Autosorb-iQ
安东帕康塔比表面和孔径分析仪:Nova系列
安东帕Anton Paar粘度计SVM 1001
安东帕Anton Paar啤酒分析系统Alcolyzer Beer Analyzing System
安东帕Anton Paar全自动成品啤酒分析系统PBA 5001 Beer
纳米压痕测试仪:Hit 300
安东帕自动化多用途粉末X射线衍射仪
SAXS/WAXS/GISAXS/RheoSAXS 实验室光束线装置
紧凑型拉曼光谱仪Cora 5001
安东帕多参数分析系统:Modulyzer
安东帕Anton Paar在线二氧化碳传感器Carbo
安东帕Anton Paar低温冰粘密浊多功能测定仪SVM 3001
安东帕Anton Paar饮料色度传感器L-Col
安东帕L-Dens 2300 密度传感器
安东帕Anton Paar在线声速传感器L-Sonic
