方案下载应用领域 | 食品/农产品 |
检测样本 | |
检测项目 | |
参考标准 | 无 |
采用安东帕微波消解仪配备微波氧燃烧技术对食品样品处理,采用ICP-MS检测,对食品中的碘元素进行检测。
Iodine determination in food samples was performed by inductively coupled plasma mass spectrometry (ICP-MS) after digestion by microwave-induced combustion (MIC). Sample masses up to 500 mg of bovine liver, corn starch, milk powder, or wheat flour were completely combusted using the MIC system. Ammonium nitrate (6 mol l−1 solution, 50 μl) was used as an aid for ignition and vessels were charged with 15 bar of O2. The use of H2O,
0.9 mmol l−1 H2O2, 10 to 50 mmol l−1 (NH4)2CO3 and 56 mmol l−1 tetramethylammonium hydroxide was investigated as absorbing solutions, as well as the suitability of performing a reflux step after the combustion process. Digestion of food samples by pressurized microwaveassisted acid digestion, microwave-assisted extraction and conventional extraction of iodine in alkaline solution were also evaluated. Iodine recoveries higher than 99% were
obtained using MIC and 50 mmol l−1 (NH4)2CO3 or 56 mmol l−1 tetramethylammonium hydroxide as absorbing solution and with 5 min for the reflux step. Accuracy was evaluated using certified reference materials (bovine muscle, corn bran, and milk powder) and agreement better than 97% was obtained. The limit of quantification by MIC and further
ICP-MS determination was 0.002 μg g−1. Blanks were always low and no memory effects were observed. Digestion by MIC allowed the processing of up to eight samples by
each run in 25 min with high efficiency of digestion (residual carbon content lower than 1%) providing a suitable medium for further iodine determination by ICP-MS.
MultiWave PRO 微波消解铂依合金
煤炭中硒含量的测定
重水含量或纯度的鉴定
安东帕康塔全自动比表面和孔径分布分析仪Autosorb-iQ
安东帕康塔比表面和孔径分析仪:Nova系列
安东帕Anton Paar粘度计SVM 1001
安东帕Anton Paar啤酒分析系统Alcolyzer Beer Analyzing System
安东帕Anton Paar全自动成品啤酒分析系统PBA 5001 Beer
纳米压痕测试仪:Hit 300
安东帕自动化多用途粉末X射线衍射仪
SAXS/WAXS/GISAXS/RheoSAXS 实验室光束线装置
紧凑型拉曼光谱仪Cora 5001
安东帕多参数分析系统:Modulyzer
安东帕Anton Paar在线二氧化碳传感器Carbo
安东帕Anton Paar低温冰粘密浊多功能测定仪SVM 3001
安东帕Anton Paar饮料色度传感器L-Col
安东帕L-Dens 2300 密度传感器
安东帕Anton Paar在线声速传感器L-Sonic
