方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 |
Adsorption isotherms of N2, Ar, CO2, and H2 were measured on selected activated carbons representing various pore size distributions. Isotherm data were analyzed using the DFT method. A good agreement was obtained between N2 and Ar results in a wide range of pore sizes. Both N2 and Ar results agree with CO2 analysis at 273 K in the range of small micropores where CO2 analysis is most applicable. Also, in this range of pores the analysis of H2 adsorption data at 77 K gives results which are consistent with the results obtained from the more conventional vapor-phase adsorptives. However, the range of PSDs calculated from H2 data extends to pore sizes smaller than those that can be characterized by other adsorbates._ 2004 Elsevier Ltd. All rights reserved.
MultiWave PRO 微波消解铂依合金
煤炭中硒含量的测定
重水含量或纯度的鉴定
安东帕康塔全自动比表面和孔径分布分析仪Autosorb-iQ
安东帕康塔比表面和孔径分析仪:Nova系列
安东帕Anton Paar粘度计SVM 1001
安东帕Anton Paar啤酒分析系统Alcolyzer Beer Analyzing System
安东帕Anton Paar全自动成品啤酒分析系统PBA 5001 Beer
纳米压痕测试仪:Hit 300
安东帕自动化多用途粉末X射线衍射仪
SAXS/WAXS/GISAXS/RheoSAXS 实验室光束线装置
紧凑型拉曼光谱仪Cora 5001
安东帕多参数分析系统:Modulyzer
安东帕Anton Paar在线二氧化碳传感器Carbo
安东帕Anton Paar低温冰粘密浊多功能测定仪SVM 3001
安东帕Anton Paar饮料色度传感器L-Col
安东帕L-Dens 2300 密度传感器
安东帕Anton Paar在线声速传感器L-Sonic
