方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
We determined the water intake of internally structured oil-loaded monoglyceride-based dispersions. This was possible through small-angle X-ray scattering (SAXS) experiments on the corresponding bulk mesophases because the structural parameters in full hydration conditions are identical to those of the dispersed particles. From low water contents to full hydration, the bulk phases depend strongly on the amount of oil. At room temperature in excess water and with increasing oil concentration, successive bicontinuous cubic, reverse hexagonal, micellar cubic, and inverse micellar-type isotropic fluid phases are found. The solubilized water is determined as a function of the oil content for each phase, and it is found to range from 5-33 wt %.
MultiWave PRO 微波消解铂依合金
煤炭中硒含量的测定
重水含量或纯度的鉴定
安东帕康塔全自动比表面和孔径分布分析仪Autosorb-iQ
安东帕康塔比表面和孔径分析仪:Nova系列
安东帕Anton Paar粘度计SVM 1001
安东帕Anton Paar啤酒分析系统Alcolyzer Beer Analyzing System
安东帕Anton Paar全自动成品啤酒分析系统PBA 5001 Beer
纳米压痕测试仪:Hit 300
安东帕自动化多用途粉末X射线衍射仪
SAXS/WAXS/GISAXS/RheoSAXS 实验室光束线装置
紧凑型拉曼光谱仪Cora 5001
安东帕多参数分析系统:Modulyzer
安东帕Anton Paar在线二氧化碳传感器Carbo
安东帕Anton Paar低温冰粘密浊多功能测定仪SVM 3001
安东帕Anton Paar饮料色度传感器L-Col
安东帕L-Dens 2300 密度传感器
安东帕Anton Paar在线声速传感器L-Sonic
