血液和血清中茶碱的分离;萃取柱:SILICA-cart SGX C 18 Isolation of Theophylline from Serum and Blood on SILICA-cart SGX C 18
文献贡献者
ERM-EC681k 高浓度RoHS标准分析参考物质证书
简介:RoHS related CRMs available from IRMM Certified Reference Materials for RoHS testing 符合RoHS指令要求塑胶(polyethylene)参考标准物质, 含四种重金属,100克颗粒/瓶 RoHS related CRMs 2 polyethylene materials certified for Br, Cd, Cl,Cr, Hg, Pb (and other elements)trace elements in HDPE ERM-EC680k 低浓度 RoHS标准分析,100克颗粒/瓶 材料Low-density polyethylene, LDPE, plastic, 组分Analyte Value 浓度值 Cd Cadmium 19.6mg/kg(certified) As Arsenic 4.1mg/kg (certified) Br Bromine 96 g/kg (certified) Cl Chlorine 102.2 mg/kg (certified) Pb Lead 13.6 mg/kg (certified) S Sulfur,Sulphur 76 mg/kg (certified) Zn Zinc 137(ind.) g/kg (indicative) Sn Tin 15.3 (ind.) mg/kg (indicative) Sb Antimony 10.1 mg/kg (certified) Cr Chromium 20.2 mg/kg (certified) Hg Mercury 4.64 mg/kg (certified) ERM-EC681k 高浓度 RoHS标准分析,100克颗粒/瓶 材料Low-density polyethylene, LDPE, plastic, 组分Analyte Value 浓度值 As Arsenic 29.1 mg/kg (certified) Cl Chlorine 0.80 g/kg (certified) Br Bromine 0.77 g/kg (certified) Cd Cadmium 137 mg/kg (certified) Cr Chromium 100 mg/kg (certified) Pb Lead 98 mg/kg (certified) Zn Zinc 1.25 (ind.) g/kg (indicative) Sn Tin 86 (ind.) mg/kg (indicative) Sb Antimony 99 mg/kg (certified) S Sulfur, Sulphur 0.63 g/kg (certified) Hg Mercury 23.7 mg/kg (certified)
1,5,5,6,6,10-六氯癸烷
胰蛋白酶抑制剂 来源于大豆
阿莫西林
5-(4-碘苯)-1-(4-硝基苯)-3-苯基甲/中断甲
熊果酸
酸性兰 1
苯
磷酸盐缓冲盐溶液
安赛蜜/乙酰磺胺酸钾
敌草快
维生素B2/核黄素
百草枯-D6
苯甲酸(安息香酸)
alpha-戊基肉桂醛
稀土试剂
已关注
产品求购
