资料下载SIMULTANEOUS OPTICAL MEASUREMENT OF PARTICLE SIZE AND SHAPE Bernhard Michel, Scientific Consulting, Am Steinbruch 1, D-91126 Rednitzhembach, Germany Wolfgang Mutter, Fritsch GmbH, Industriestrasse 8, D-55743 Idar-Oberstein, Germany Abstract. Conventional optical particle sizers evaluate the dependence of scattered light on the polar angle (angle relative to the optical axis) in order to determine size distributions of particles. The dependence on the azimuth angle (around the optical axis) commonly is not considered, although it contains valuable information about particle shape. We present a novel optical particle analyzer developed by Fritsch GmbH, which is based on an inverse Fourier setup. It uses a custom-made silicon sensor to detect the dependence of the scattered light on both polar and azimuth angle, thus enabling the simultaneous determination of particle size and shape. The particle shape analysis is currently restricted to the Fraunhofer regime, starting with a minimum size of 3 μm. For the particle size measurement, small- and wide-angle light scattering is evaluated, leading to a possible dynamic range from 10 nm up to 2 mm. The main advantages of the new particle analyzer are its cost-efficiency, because it is an all-in-one solution,
PFA超高纯电子级试剂包装瓶-G5级湿电子化学品包装
简介:湿电子化学品常常易燃、易爆、强腐蚀,不仅要求产品在贮存的有效期内杂质及颗粒不能有明显的增加,而且要求包装后的产品在运输及使用过程中对环境不能有泄漏的危险。目前最广泛使用的包装材料是高密度度聚乙烯(HDPE)、四氟乙烯和氟烷基乙烯基醚共聚物(PFA)。 目前国际上领先的高纯试剂生产商大多数选用以科慕(原杜邦)的PFA原料生产的包装瓶,其中认可度最高的是美国Savillex PFA包装瓶,使用Savillex PFA高纯试剂包装瓶储存G5级试剂1年以上仍能保持试剂的品质稳定如初。
德国MBBM主动磁场补偿系统
简介:德国Müller-BBM的主动磁场补偿系统MACOM II®,该有源磁场补偿系统来自Müller-BBM的:使用MACOM II®,只需相对较低的成本付出,MACOM II®即可为您的系统实现最佳的磁场条件。 MACOMII®可自动补偿干扰磁场。在调试期间正确设置后,系统无需进一步维护。MACOMII®的显示屏用于操作系统并监控其功能,如有必要,还可以在上面查看和调整所有参数。在操作期间,显示器显示所有三个坐标方向上的剩余磁场或产生补偿磁场所需的线圈电流。
饲料中呋喃唑酮、呋喃妥因、呋喃西林含量的检测方法液相色谱法
简介:4.方法提要 样品经乙腈-N,N-二甲基甲酰胺(DMF)混合液提取,提取液用阳离子交换柱净化,高效液相色谱-紫外检测器测定,外标法定量。 6.仪器 高效液相色谱仪、振荡器、固相萃取装置带真空泵、离心机转速≥4000r/min、吹氮浓缩装置、旋转蒸发器、我选混匀器、不锈钢筛筛孔1mm。
黑龙江省哈尔滨市阿城区粮食局一批采购清单
简介:哈尔滨市阿城区粮食局拟采购:重金属快速检测仪、快速测汞仪、粮食真菌毒素快速检测(胶体金)、农药残留快速检测仪、近红外谷物分析仪、转基因快速检测仪等设备。
实验室 全自动固液测汞仪
简介:全自动流体分析系统;成熟可靠的检测方法:冷蒸气原子吸(CVAAS);结合金富集阱,可使最高灵敏度达到<1ng/L;AULAWIN 软件易于操作;可选配全自动样品消解模块(ASD)用于样品的消解。 AULA 254 用于液体样品和样品消解溶液中痕量汞的全自动检测。该仪器进行常规分析时,样品按照预设定的程序依次完成检测,因此大大提高了实验效率。应用领域包括:水,废水,土壤和污水适用于EPA 方法:245.1,245.7,1631,7470 和 7471A医药行业(尿液,血液,唾液,头发)、化工行业(过程监控,质量控制)、地球化学(地质和矿物样品)、石油石化行业、冶金和材料测试等领域。
ICP-MS PFA惰性进样套件 兼容PE NexION 300系列
PFA质谱惰性进样套件 兼容Thermo Element 2/Nept
PFA惰性进样套件 兼容安捷伦7500/7700/78x0x系列
酸逆流清洗机savillex美国VC Ultra酸蒸清洗器
PURELAB® Quest 纯水机
PURELAB Micra系列 纯水机
PURELAB flex系列 纯水机
PURELAB Classic系列 纯水机
ELGA 实验室中央纯水系统CENTRA
ELGA纯水机 PURELAB® Chorus系列
MULLER-BBM MACOM II ®主动磁场补偿系统
烟囱气体汞监测仪SM-4 Mobile
便携式总烃监测仪OVF3000
超低流量加热型SHED FID总烃监测仪
便携式汞分析仪Traker 3000XS
