方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The sample for the laser particle sizer (approx. 200 mg - 1g) should correspond to the entire quantity of source material with regard to particle type and distribution. The rotary cone sample divider "laborette 27" is very well suited for dividing of dry laboratory samples or suspensions because various dividing heads with different division ratios can be selected (see special printing of Aufbereitungs-Technik, Volume 9 / 1996). Depending on the dividing head used, up to 3000 divisions per minute can be achieved. Possible divisions: 1:8, 1:10 and 1:30 Example: An existing laboratory sample of 50 ml (g) or 100 ml (g) could first be divided with the installed dividing head 1:10 and then with the dividing head 1:30 so that the quantity of 200 - 400 mg required for the laser particle sizer is available.
LabAnalyzer 254 汞分析仪
VM-300O、Lab-254用于煤燃烧过程中汞的监测控制.pdf
VM-3000、Lab-254 用于煤燃烧和环境保护的研究
ICP-MS PFA惰性进样套件 兼容PE NexION 300系列
PFA质谱惰性进样套件 兼容Thermo Element 2/Nept
PFA惰性进样套件 兼容安捷伦7500/7700/78x0x系列
酸逆流清洗机savillex美国VC Ultra酸蒸清洗器
PURELAB® Quest 纯水机
PURELAB Micra系列 纯水机
PURELAB flex系列 纯水机
PURELAB Classic系列 纯水机
ELGA 实验室中央纯水系统CENTRA
ELGA纯水机 PURELAB® Chorus系列
MULLER-BBM MACOM II ®主动磁场补偿系统
烟囱气体汞监测仪SM-4 Mobile
便携式总烃监测仪OVF3000
超低流量加热型SHED FID总烃监测仪
便携式汞分析仪Traker 3000XS
