方案下载应用领域 | 生物产业 |
检测样本 | 其他 |
检测项目 | |
参考标准 | 热重天平法 |
The LECO TGA801 is a macro thermogravimetric analyzer designed to determine moisture, volatile and ash content of materials by measuring the change in mass of the sample as a function of the oven temperature while controlling the atmosphere and ventilation rate. The TGA801 allows up to 19 samples to be analyzed simultaneously.
利用力可LECO TGA801热重分析仪分析植物组织中水分挥发分和灰分,结果如下:
凯氏定氮与杜马斯定氮—概述和比较
力可LECO SC832碳硫分析仪分析
力可LECO RHEN602分析铝及铝合金中氢含量
