资料下载Cell size distribution of Solanum chrysotrichum cell suspension cultures was determined using mechanical sieving and an image analysis system. The results were compared using the sieve size (<0.25, 0.25–0.50, 0.5–1.0 and >1.00 mm) as the criterion. Mechanical sieving as well as image analysis showed that S.chrysotrichum cultures developed in shake flasks present a similar tendency to increase in aggregate size as growth persists. However, there are considerable differences in the values of each fraction........
ZM200在软粘性样品中的应用
简介:粘性预脆化,把样品放入也液氮中冷冻,并用滑石粉来降低粘附性。ZM200的性能,对于糖果的研磨的粉末,还是最适合使用的
巧克力等含油含脂含糖的食品也能实现精细的研磨
简介:GM200特别适合含油含脂含糖等黏性样品的研磨,具体可以根据你样品的特性来设置研磨时间,从而获取你所要求的样品。
PM100在矿物学领域的应用
简介:根据您的对样品的要求,可以选用适合的研磨罐和不同材质的研磨球,通过调节研磨时间来得到你所需要的样品。
MM400混合球磨仪在医药领域的应用
简介:根据您的具体样品,选择合适的配件。对于一些硬脆性和含油脂的样品,可以在烘焙箱里面加工一下,为确保样品的质量。
植物叶片顺利提取DNA\RNA,组织破碎是关键
简介:用于提取DNA,RNA的样品,样品需要被完全破碎,配以何当的适配器和研磨球,通过调节研磨时间来获取你所需要的样品。
