资料下载All EU countries have to adopt these directives through national legislation, which will not only affect EU members but also countries which export their products to Europe. In other parts of the world, e.g. California and China, these directives have also been transformed into national regulations. The aim of the Waste of Electrical and Electronic Equipment (WEEE) directive is the environmentally acceptable disposal of used electrical appliances, some of which contain hazardous components, which are increasingly being found in household waste. Among these are electric irons, food processors, electric shavers, toasters and electric tools that have a low recycling quota. The objective of WEEE is that the total amount of materials which are not suitable for substantial or thermal recycling should be strongly limited and that the recycling quota should amount to 75 % by the end of this year. A further directive, Restriction of Hazardous Substances (RoHS), on limitations of use stipulates that from July 2006, the amount of certain substances (such as lead, mercury, cadmium) and brominated flameproofing agents in new electric and electronic appliances must not exceed a defined limit. In any case, the recyclers and disposers of electronic scrap, as well as the manufacturers of new electric appliances, will very soon be required to be able to carry out analytical determinations to demonstrate that these directives are being observed. (...)
ZM200在软粘性样品中的应用
简介:粘性预脆化,把样品放入也液氮中冷冻,并用滑石粉来降低粘附性。ZM200的性能,对于糖果的研磨的粉末,还是最适合使用的
巧克力等含油含脂含糖的食品也能实现精细的研磨
简介:GM200特别适合含油含脂含糖等黏性样品的研磨,具体可以根据你样品的特性来设置研磨时间,从而获取你所要求的样品。
PM100在矿物学领域的应用
简介:根据您的对样品的要求,可以选用适合的研磨罐和不同材质的研磨球,通过调节研磨时间来得到你所需要的样品。
MM400混合球磨仪在医药领域的应用
简介:根据您的具体样品,选择合适的配件。对于一些硬脆性和含油脂的样品,可以在烘焙箱里面加工一下,为确保样品的质量。
植物叶片顺利提取DNA\RNA,组织破碎是关键
简介:用于提取DNA,RNA的样品,样品需要被完全破碎,配以何当的适配器和研磨球,通过调节研磨时间来获取你所需要的样品。
