资料下载A pot experiment focused on the study of factors influencingthalliumtransferfromcontaminatedsoilsintokale(green cabbage, Brassica oleracea L. var. acephala, variety Winterbor F1) was evaluated. Threedifferenttypesoftopsoils with naturally low content of thallium (heavy, medium and medium-light soil) were used for pot experiments. Thesoilswerecontaminatedwiththalliumsulfatetoachievefivelevelsofcontamination(0,0.52,2.10,4.20and 5.88 mg/kg). Thereweresixreplicatesforeachcombination(90potsintheexperiment).Thefirstpartof theexperiment started in the year of contamination (2001) and continued in 2003. Thesoilsamplesandthesamplesofkale (leaves and stalks were sampled separately) were collected and analysed. Kale was found to be able to accumulate Tl without any influenceonyield.Thehighestthalliumconcentrationwasfoundintheleavesofkaleinthefirstyear of the experiment and reached 326 mg/kg dry matter. Bioaccumulation factor (Biological Absorption Coefficient – BAC) was found to be over 80 during the firstyearoftheexperiment.InthethirdyeartheBACwasaround3 for the soil with the highest pH and the highest organic matter content but as high as 15 for an acid soil with the lowest content of organic matter and the lowest Cation Exchange Capacity (CEC) of soils.
ZM200在软粘性样品中的应用
简介:粘性预脆化,把样品放入也液氮中冷冻,并用滑石粉来降低粘附性。ZM200的性能,对于糖果的研磨的粉末,还是最适合使用的
巧克力等含油含脂含糖的食品也能实现精细的研磨
简介:GM200特别适合含油含脂含糖等黏性样品的研磨,具体可以根据你样品的特性来设置研磨时间,从而获取你所要求的样品。
PM100在矿物学领域的应用
简介:根据您的对样品的要求,可以选用适合的研磨罐和不同材质的研磨球,通过调节研磨时间来得到你所需要的样品。
MM400混合球磨仪在医药领域的应用
简介:根据您的具体样品,选择合适的配件。对于一些硬脆性和含油脂的样品,可以在烘焙箱里面加工一下,为确保样品的质量。
植物叶片顺利提取DNA\RNA,组织破碎是关键
简介:用于提取DNA,RNA的样品,样品需要被完全破碎,配以何当的适配器和研磨球,通过调节研磨时间来获取你所需要的样品。
