方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The reproductibility of repeated total N analyses using the automated method was comparable to results obtained with a semi-micro Kjeldahl procedure. However, the automated method gave results which were 3% to 5% higher than those obtained with the Kjeldahl procedure. Since only small samples can be analysed, careful sample homogenization and fine grinding are very important.
万能食品研磨机
陶瓷材料如何进行研磨呢
木质材料精细研磨的最佳解决方案
