方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Nanocrystalline powders of a soft FeNbLi-doped PZT material have been prepared by a novel mechanochemical process consisting of mixing the stoichiometric oxides in a planetary ball mill for prolonged times up to 80 h. The constituent oxides were reacted in a tungsten carbide vial with balls of 5, 10 and 20 mm in diameter and a ball/powder ratio of 15/1. The chemical reaction between the component oxides was triggered after 20 h of energetic milling and was completed after 80 h. The XRD of the reacted nanopowder showed the well known perovskite structure. Compacted samples of this powder were sintered between 800–1300◦C for 3 h and the main piezoelectric properties were determined. The density of the sintered samples reached nearly 99% of the theoretical density at 1100◦C and showed good piezoelectric characteristics: planar coupling factor of 0.66, dielectric displacement constant d33 of 550 pm/V, mechanical quality factor of 85, and relative dielectric constant of 3800. The possible mechanisms for solid staeaction of mechanically activated nanopowders such as local heating and pressure at collision as well as defects diffusion are discussed. C 2004 Kluwer Academic Publishers
万能食品研磨机
陶瓷材料如何进行研磨呢
木质材料精细研磨的最佳解决方案
