方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A simplified procedure for extracting ions from soil with ion-exchange resins is reported. The resin, placed in nylon-netting bags, were immersed in soil suspensions and shaken. Compared to the conventional procedure, where the resin beads are freely suspended in the soil-water mixture, this bag-procedure allowed quicker separation of resin from the soil suspensions. Furthermore, the severe soil grinding as done in the conventional procedure was eliminated. Phosphate was extracted from 4 Danish soils using both procedures. The bag-procedure resulted in slightly higher values than did the conventional procedure.
万能食品研磨机
陶瓷材料如何进行研磨呢
木质材料精细研磨的最佳解决方案
