方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Cell size distribution of Solanum chrysotrichum cell suspension cultures was determined using mechanical sieving and an image analysis system. The results were compared using the sieve size (<0.25, 0.25–0.50, 0.5–1.0 and >1.00 mm) as the criterion. Mechanical sieving as well as image analysis showed that S.chrysotrichum cultures developed in shake flasks present a similar tendency to increase in aggregate size as growth persists. However, there are considerable differences in the values of each fraction........
万能食品研磨机
陶瓷材料如何进行研磨呢
木质材料精细研磨的最佳解决方案
