方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Yeast spaghetti are produced by pressing yeast through small holes into a beaker filled with liquid nitrogen. The holes (~1.0mm Ø) are punched into the bottom of a 50mL Falcon tube that contains 10-20mL of pelleted yeast obtained after centrifugal harvest of a 2L late log. culture. Pressure is employed manually by inserting the piston of a 60mL disposable syringe into the tube. Yeast spaghettis (treated with protease inhibitors) can be stored at -80°C.
万能食品研磨机
陶瓷材料如何进行研磨呢
木质材料精细研磨的最佳解决方案
