上海同田生物技术:运用高速逆流色谱法分离藤黄酸立体异构体
2017-09-21 13:41  下载量:1
资料下载
Abstract: A recycling counter-current chromatographic system was first set up with a high-speed counter-current chromatography instrument coupled with a column switching valve. This system was first successfully applied to the preparative separation of epimers, gambogic acid and epigambogic acid from Garcinia hanburyi using n-hexane–methanol–water (5:4:1, v/v/v) as the two-phase solvent system. As a result, 28.2 mg gambogic acid and 18.4 mg epigambogic acid were separated from 50 mg of mixture. Their purities were both above 97% as determined by HPLC. The chemical structures were then identified by their H-NMR and C-NMR spectra.
资料下载
文献贡献者
相关资料 更多
当前位置: 泰坦科技 资料 上海同田生物技术:运用高速逆流色谱法分离藤黄酸立体异构体
