方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract: Following an initial cleaning-up step on the D101 macroporous resin,a preparative high-speed counter-current chromatography (HSCCC) with a two-phase solvent system composed of n-hexane–ethyl acetate–methanol–water (1:0.9:0.9:1, v/v) was used to isolate and separate schizandrin and gomisin A from Schisandra chinensis. A total of 107 mg schizandrin and 36 mg gomisin A with purities of 99.5% and 99.1% were obtained from 400 mg crude extract in one-step elution and less than 3h,and the structure identification was performed by UV, IR, MS,H-NMR and C-NMR.
上海同田生物技术:运用高速逆流色谱法从仙茅中分离仙茅甙和仙茅甙乙
上海同田生物技术:运用高速逆流色谱和ELSD联用技术从Adenophora tetraphlla(南沙参)根茎中分离化学成分
上海同田生物技术:高速逆流色谱法分离制备丹酚酸B
