资料下载A method is described for determining volatile nitrosamines in baby bottle rubber nipples and pacifiers. The method consists of overnight soaking of the sample with dichloromethane in the presence of propyl gallate, an inhibitor for artifactual formation of nitrosamines; extraction with dichloromethane using an ambient temperature column procedure; distillation from aqueous alkali; extraction of the aqueous distillate with dichloromethane and concentration of the extract using a Kuderna-Danish concentrator; and final analysis by gas chromatography with detection by thermal energy analyzer. Major improvements over other published methods include a simpler extraction, a more efficient distillation and concentration to minimize losses, and incorporation of propyl gallate inhibitor as well as of a test to detect unsuitable dichloromethane solvent that otherwise might lead to artifactual formation. The method is highly accurate (approximately 90% recovery) and precise (av. CV = 4.7% at greater than 9 ppb levels) and is applicable to determination of nitrosamines in both rubber- and plastic-based products.
瑞士CTC进样器各型号耗材
简介:Syringe Kits 4 Syringes and Syringe Plungers 5 Trays, Traysets and Stacks 6 Thermostatted Trayholders 7 - 8 PAL Dilutor 8 FlowCell, Washstations and Consumables 9 - 10 SPME Options 10 ITEX-2, Headspace and xt- Upgrade Kits 11 GC Mounting Kits and MHE Tool 12 Barcode Reader 13 Software, IQ/OQ Protocols and Tools 13
CTC进样器维护手册
简介:1. 任何时候不要触碰控制面板中,不知道含义的按钮、部件,以免引起机器错误操作。 2. 机器运动中如果发生异响,或发生碰撞立刻关机,查明原因后再重启 3. 长时间停机后,或使用中,最好能隔一段时间取下进样针,手动检查推杆是否顺畅, 吸液检查针头是否堵塞。推杆被堵塞是其最常见的故障。 4. 如需清洁轨道,用软布,无尘纸即可,可用少量酒精擦拭 5. 任何情况下,不要向机器任何部位加润滑油。CTC 为无润滑油设计。
瑞士CTC多功能自动进样器中文产品手册
简介:瑞士CTC分析仪器股份公司(CTC Analytics AG) 是世界领先的专业色谱进样设备厂商,其HPLC/LC MS、GC/GC MS 精密进样系统,因其独特的机械设计、可靠的运行性能,被ABI、Waters、Agilent、Varian等众多厂商所推崇。
CSI 300详解
简介:CSI 300设计原理,分析实列。 300系列是一个新设计的快速气相色谱仪来自英国ACS /CSI。300系列色谱仪并不是像常规气相色谱仪那样使用柱温箱加热,而是直接对色谱柱进行直接加热,该设计可以实现更快的升温和降温,这样就可以实现非常显著色谱快速分析优势,由于300系列不需要较大的柱温箱和额外的加热设备,所以它自身可以设计的比常规气相色谱仪更紧凑, 300系列尺寸仅为320x370 x340毫米。
RTC 全自动气相液相进样器
PAL3 气相液相色谱通用多功能自动进样平台
PAL 多种多样的选件: 功能模块、切换阀组与控制软件
Dynamic Load and Wash 动态洗针快速进样功能
液质全自动在线固相微萃取
液质血液样品自动化进样平台
OPTIC 4多模式进样口
气相色谱多功能自动进样器 ITEX-2微管捕集模块
瑞士CTC多功能进样器 Combi-PAL 液体/顶空/固相微萃取/ITEX
瑞士CTC HTC-PAL液相/液质连用多功能自动进样器
英国CSI 快速气相色谱仪
英国CSI TEA610 热能分析仪(原Thermo Electron厂牌)
热脱附多功能全自动进样器
SPDE固相动态萃取多功能全自动进样器
GC-PAL 气相色谱及质谱连用(GC-MS)液体进样器系统
